Aruba is…
The leader in secure, reliable, manageable and scalable distributed enterprise networks.
Network Rightsizing
The Right Infrastructure for Network Rightsizing
Network Rightsizing is a contemporary network design strategy that significantly reduces costs and carbon emissions while simultaneously increasing mobility.
Network Rightsizing leverages server virtualization and the mass shift towards mobile devices in the enterprise to reduce the amount of network equipment needed at the edge. Ideal for refresh projects and new builds, Network Rightsizing has proven to save millions of dollars in one-time and on-going expenses.
Network Rightsizing can be applied in two main areas:
  • In large office and campus locations: the wire-like performance of Aruba's 802.11n wireless LAN present a refreshing option to reduce number of edge Ethernet Switches, as users switch away from fixed desktops to Wi-Fi-capable laptops. Especially useful during an edge Switch refresh, offsetting wired ports with cost-effective 802.11n wireless LANs significantly reduces the equipment upgrade bills. The result is a network that enables user mobility, while lowering energy usage and annual maintenance costs.
  • In small branch locations: cloud services offered by Aruba's VBN solution eliminate the need for up to seven network and security services that would otherwise be installed in every location. With fewer services physically located in every branch location, installation and configuration are simplified to a no-touch process, while maintenance tasks are pushed to a central location. Additionally, Aruba's VBN securely delivers HQ-quality services to the branch over any broadband connection… creating an opportunity to replace costly private WAN connections.
Speak With
an Engineer
Let's Talk »
Aruba's Edge:
A Webcast Series
View Webcasts »
Network Rightsizing
Watch Now »
